xzv avatar image
xzv asked
Multiplus randomly disappears from Remote Console and stops working
I've now experienced it twice that the Multiplus disappeared from the list of devices in the Remote Console. Unfortunately, that's not all, it can no longer be controlled via Node-RED either.
My suspicion is that it could be related to occasionally changing the switch position (Off / On) in Node-RED. However, I cannot (yet) say whether this is really related or not.
At the moment, the only option in this situation is to restart the system. That's bad because I need to notice this situation...
Any idea what I could check or log in this situation?
Setup: Multiplus II GX + Node-RED + VenusOS 3.20
I've checked the logs in /var/log/messages. Here's something strange, it looks like a random reboot during the night:
Apr  2 02:58:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:08:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:18:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:28:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:38:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:48:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 03:58:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 04:08:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 04:16:54 nanopi daemon.err dnsmasq[590]: failed to send packet: Network is unreachable
Apr  2 04:16:54 nanopi daemon.err dnsmasq[590]: failed to send packet: Address family not supported by protocol
Apr  2 04:18:16 nanopi daemon.notice wpa_supplicant[729]: wifi0: WPA: Group rekeying completed with 3e:37:12:ef:0f:43 [GTK=CCMP]
Apr  2 04:20:53 nanopi daemon.err dnsmasq[590]: failed to send packet: Network is unreachable
Apr  2 04:20:53 nanopi daemon.err dnsmasq[590]: failed to send packet: Address family not supported by protocol
Apr  2 04:21:36 nanopi user.notice shutdown[4034]: shutting down for system reboot
Apr  2 04:21:36 nanopi daemon.info init: Switching to runlevel: 6
Apr  2 04:21:37 nanopi user.notice root: Stopping watchdog (keeping hw watchdog alive)
Apr  2 04:21:37 nanopi user.crit kernel: [35414.575359] watchdog: watchdog0: watchdog did not stop!
Apr  2 04:21:37 nanopi daemon.info haveged: haveged: Stopping due to signal 15
Apr  2 04:21:37 nanopi daemon.info avahi-autoipd(ll-eth0)[680]: Got SIGTERM, quitting.
Apr  2 04:21:37 nanopi daemon.info avahi-autoipd(ll-eth0)[680]: Callout STOP, address 169.254.9.146 on interface ll-eth0
Apr  2 04:21:37 nanopi daemon.info connmand[668]: eth0 {RX} 487877 packets 315817240 bytes
Apr  2 04:21:37 nanopi daemon.info connmand[668]: eth0 {TX} 290480 packets 62069865 bytes
Apr  2 04:21:37 nanopi daemon.info connmand[668]: eth0 {newlink} index 3 address C0:61:9A:B2:CA:73 mtu 1450
Apr  2 04:21:37 nanopi daemon.info connmand[668]: eth0 {newlink} index 3 operstate 6 <UP>
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {RX} 76698 packets 10250041 bytes
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {TX} 4382 packets 1776676 bytes
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {update} flags 4098 <DOWN>
Apr  2 04:21:37 nanopi daemon.info connmand[668]: ll-eth0 {newlink} index 6 address 3A:32:B0:AB:5F:3A mtu 1450
Apr  2 04:21:37 nanopi daemon.info connmand[668]: ll-eth0 {newlink} index 6 operstate 2 <DOWN>
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {del} route fe80:: gw :: scope 0 <UNIVERSE>
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {del} address 169.254.9.146/16 label ll-eth0
Apr  2 04:21:37 nanopi daemon.info connmand[668]: ll-eth0 {dellink} index 6 operstate 2 <DOWN>
Apr  2 04:21:37 nanopi daemon.info connmand[668]: (null) {remove} index 6
Apr  2 04:21:37 nanopi daemon.info avahi-autoipd(ll-eth0)[685]: client: Cannot find device "ll-eth0"
Apr  2 04:21:37 nanopi daemon.warn avahi-autoipd(ll-eth0)[685]: Script execution failed with return value 1
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Got SIGTERM, quitting.
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface wifi0.IPv6 with address fe80::5ec5:63ff:f>
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface wifi0.IPv4 with address 192.168.189.12.
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::c261:9aff:fe>
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.178.57.
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Apr  2 04:21:37 nanopi daemon.info avahi-daemon[635]: avahi-daemon 0.8 exiting.
Apr  2 04:21:37 nanopi daemon.info bluetoothd[585]: Terminating
Apr  2 04:21:37 nanopi daemon.info bluetoothd[585]: Exit
Apr  2 04:21:37 nanopi daemon.err connmand[668]: D-Bus disconnect
Apr  2 04:21:37 nanopi daemon.info connmand[668]: rp_filter restored to 0
Apr  2 04:21:37 nanopi daemon.notice wpa_supplicant[729]: wifi0: CTRL-EVENT-DISCONNECTED bssid=3e:37:12:ef:0f:43 reason=3 locally_generat>
Apr  2 04:21:37 nanopi daemon.err wpa_supplicant[729]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_su>
Apr  2 04:21:38 nanopi daemon.err connmand[668]: Time request for server 192.168.178.1 failed (101/Network is unreachable)
Apr  2 04:21:38 nanopi daemon.info dnsmasq[590]: exiting on receipt of SIGTERM
Apr  2 04:21:38 nanopi user.info kernel: [35415.527472] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Remove interface wifi0 [ wifi ]
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Remove interface eth0 [ ethernet ]
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Remove interface ap0 [ wifi ]
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Removing configuration wifi_5cc563064710_4461686f696d_managed_psk
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Removing configuration wifi_5cc563064710_4261756d75656c6c6572_managed_psk
Apr  2 04:21:38 nanopi daemon.info connmand[668]: tailscale0 {remove} index 7
Apr  2 04:21:38 nanopi daemon.info connmand[668]: wifi0 {remove} index 4
Apr  2 04:21:38 nanopi daemon.info connmand[668]: eth0 {remove} index 3
Apr  2 04:21:38 nanopi daemon.info connmand[668]: ap0 {remove} index 5
Apr  2 04:21:38 nanopi daemon.info connmand[668]: Exit
Apr  1 18:31:32 nanopi daemon.info dnsmasq[595]: started, version 2.83 cachesize 150
Apr  2 04:21:38 nanopi daemon.warn dnsmasq[595]: overflow: 4 log entries lost
Apr  2 04:21:38 nanopi daemon.notice wpa_supplicant[729]: nl80211: deinit ifname=wifi0 disabled_11b_rates=0
Apr  2 04:21:38 nanopi user.info connmand_watch: no longer restarting the connmand process
Apr  2 04:21:38 nanopi daemon.notice wpa_supplicant[729]: wifi0: CTRL-EVENT-TERMINATING
Apr  2 04:21:39 nanopi syslog.info syslogd exiting
Apr  2 04:21:58 nanopi syslog.info syslogd started: BusyBox v1.31.1
Apr  2 04:21:58 nanopi user.notice kernel: klogd started: BusyBox v1.31.1 (2024-03-11 17:57:01 UTC)
Apr  2 04:21:58 nanopi user.info kernel: [    0.000000] Booting Linux on physical CPU 0x0
Venus OSremote consolebug report
nickdb avatar image
nickdb answered ·
Wasn't aware that the system would appear when it is remotely turned off.
Always under the impression that "off" needed to be used with care.
xzv avatar image xzv commented ·
The inverter is then just shown as "off" but is still there, just AC is disconnected. Normally that works like a charm. Saves around 20 Watts in consumption during longer standby periods.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Remote Console on VRM - Troubleshooting
