jameswest avatar image
jameswest asked
MQTT not updating enabled flag in ESS charge schedule
Cerbo GX v2.94
Action: Using MQTT to modify ESS > Scheduled charging.
e.g. W/XXX/settings/0/Settings/CGwacs/BatteryLife/Schedule/Charge/0/Day
Result: Most modifications work as expected and the changes are reflected in the Cerbo GX UI. However, when changing the day value between a positive & negative value via MQTT, which should enable or disable the schedule, the change is not reflected in the details page of UI. The enabled switch is stuck in it's current state. If stuck in the on state, the Day field changes to --
The overview page of scheduled charging does however reflect the correct state.
Venus OSbug report
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
