wedgehog avatar image
wedgehog asked
I'm stupid and need one of you smart guys to explain something
Try as I do I just cannot get my head around some of these Git hub pages, the one I am presently pulling my hair out on says this.
Un-official meross-cli
Prerequisite
Install node v14+, then run npm ci --prod to setup dependencies.
Usage
For command and its flags, run node meross help for built-in usage & help.
Commands
Currently implemented commands:
  • login
  • generate-config
Run node meross <command> --help for command help.
I am assuming because it's to do with Node Red that the first part "Install node v14+," is talking about installing Node Red and they want v14 or greater? I already have Node Red running in a virtual machine on my Synology 920DS Nas it is version 3.1.6 I is that greater than v14 should there be a decimal point V1.4?
Second it says "then run npm ci --prod" well I tried running that in the HomeAssistant Terminal screen and it says no such command, I logged in from my pc with putty and did it in that same thing, and so we go, I must be stupid I haven't a clue where I should be running this.
Would it ruin some eternal plan if the Git hub people even gave a clue to help out the learners?
Could one of you smart guys give me some help please. Bob
Help
nickdb avatar image
nickdb answered ·
Please keep content related to Victron products. Thanks
