colin-mackay avatar image
colin-mackay asked
Battery Monitor error 512 and pylontech battery
We have added a US 3000 Pylontech battery module to an existing bank of 5 US 3000s. On completing the installation and switching on - all battery modules are operating normally and the system itself is operating normally with no faults showing. the battery monitor however is showing the fault;
this alarm has been active now for 24 hours. what is the reason and how do I rectify it. I suspect it is a result of and arc when closing the fuse to the inverter - but as i say the alarm is still active.
The system consists of;
1 x 8KvA Quattro
2 x 150v 70A controllers
1 x venus GX
6 x Pylontech 3500 - set up in two strings of three
24 x 335w solar modules
Pylontecherrorbattery system voltage
Hi @colin mackay
Someone has set an alarm, and it's currently active:
colin-mackay answered ·
Hi Daniel
thanks for that - what should the correct settings be
With the maximum charge discharge current at 74A x 6 modules - a maximum setting of 200a should be more than safe i assume?
where would the minimum setting be
Victron Pylontech battery compatibility guide
