ekki-k avatar image
ekki-k asked
Include Battery Data in Home Assistant Energy dashboard
I use the sfstar hass-victron integration with 4 devices and 247 entities.
Unfortunately none of the battery entities qualifies to be included in the energy dashboard (Therefore showing 0 kWh, ;-) ) :
According to the documentation the "device_class must be energy for electricity grid". Obviously this is not the case for any entity. To bring the victron energy values into the energy dashboard would be ideal.
I see the following possibilities :
- sfstar include "new" entities with device_class energy
- some calculations are made within Home Assistant
- some Node-RED magic coding
Anyone has already success bringing the battery values into the Homeassistant Energy dashboard ?
Energy Meterbatteryhome assistant
Joe avatar image
Joe answered ·
+1, would need this aswell! All calculations with Templates only work Part time... If one solar charger Wales up later than others in the morning, those Templates sometimes report a minus yield.
klaushab avatar image
klaushab answered ·
this is my solution and it works well:
configuration.yaml:
modbus: !include victron.yaml
sensor:
  - platform: template
    sensors:
      # Template sensor for values of energy charge battery (power > 0)
      power_discharge:
        friendly_name: "Batterie Leistung Entladung"
        unique_id: aee34f60-272f-46f0-b938-33659a005365
        unit_of_measurement: "W"
        value_template: >-
          {% if (states('sensor.victron_battery_power_system')|float(0)) < 0 %}
  { (states('sensor.victron_battery_power_system')|float(0) * - 1) }}
          {% else %}
  { 0 }}
          {% endif %}
      power_discharge:
        value_template: >-
          {% else %}
  { 0 }}
          {% endif %}
  # Sensor for Riemann sum of energy charged in battery (W -> Wh)
  - platform: integration
    source: sensor.power_charge
    unique_id: b03797b4-077f-41bf-920d-9132d6dafba9
    unit_prefix: k
    round: 2
    method: left
  # Sensor for Riemann sum of energy discharged in battery (W -> Wh)
    source: sensor.power_discharge
    unique_id: b03797b4-077f-41bf-920d-9132d6dafba0
    unit_prefix: k
    round: 2
    method: left
utility_meter:
  energy_charged_daily:
    source: sensor.batterie_gespeicherte_energie
    unique_id: c8a28599-4a1b-4cdd-8727-fa771575ffe9
    name: Batterie gespeichert taeglich
    cycle: daily
  energy_discharged_daily:
    source: sensor.batterie_entladene_energie
    unique_id: c8a28599-4a1b-4cdd-8727-fa771575ffe1
    name: Batterie entladen taeglich
    cycle: daily
victron.yaml:
# Victron Configuration.
- name: victron
  type: tcp
  host: 192.168.0.7
  port: 502
  sensors:
    - name: "Victron Battery Power System"
      unique_id: 5bec2ff5-99df-499c-840e-0c67fabb0f5e
      scan_interval: 5
      slave: 100
      address: 842
      data_type: int16
      scale: 1.0
      precision: 0
      device_class: power
Configuration of Energy-Dashbord:
Hope it works for you too
Klaus
ekki-k avatar image
ekki-k answered ·
Thanks ! Looks good. I will give it a try. braamvh reported, that the much simpler way works for him :
"sensor.victron_battery_history_chargedenergy and sensor.victron_battery_history_dischargedenergy work very well with the energy dashboard"
I use these values since over a year now and hope, some new SW would bring them to life. In my instance these values are always "0".
Energy Meter Selection Guide
