Has anyone had luck connecting a Cerbo GX to Sungold BMS via Bluetooth? I just bought four of the 12v 100Ah Sungold batteries, and I am hoping they will connect.
This will not be possible, as with the sole exception of Ruuvi sensors, nothing at all connects to the Cerbo using bluetooth. Cerbo bluetooth is, nearly without exception, for the sole purpose of easily setting up your wifi/LAN connection.
87 People are following this question.
