philipa avatar image
philipa asked
How do I use Cerbo GX PV monitoring when VE.Bus BMS is using the MPTT VE.Direct port?
I have a VE.Bus BMS connected to a MPPT 100/50 solar charger via a VE.Direct non-inverting remote on/off cable. The MPTT has a single VE.Direct port, so I can't monitor it using my Cerbo GX.
I guess one option is to install a separate charge disconnect device. Any other ideas?
Thanks.
MPPT Controllerscerbo gxBMSVE.Direct
