fenix avatar image
fenix asked
How do I optimise an MPPT-100/50 , BMV-712 , with a Starter battery and Smart Battery Sense?
what would be the best to optimize the battery charging with those equipment's in my small motorHome
- MPPT-100/50
- BM-712 with temp
- Smart Battery Sense for the Starter battery of the vehicles
How will the temperature sensor will be used in this case?
Will the MPPT-100/50 will take the BM-712 Temp in consideration ?
battery chargingBMV Battery MonitorsolarSmart Battery Sense
klim8skeptic avatar image
klim8skeptic answered ·
"Will the MPPT-100/50 will take the BM-712 Temp in consideration ?"
You create a Bluetooth network between the charge controller and the BMV. That way the BMV will share temperature and voltage data with the mppt.
Make sure you have the SmartSolar MPPT. If you have the BlueSolar MPPT, you will also need a bluetooth dongle.
