elektrowiesel avatar image
elektrowiesel asked
Car battery reconditioning
Our Honda has a 70Ah EFB battery which is about one year old. It was not used for a year. Mostly I reloaded the battery with a old Ctec device, about once a month. But now we made a large trip. The second day, the starter didn`t do anything. After a few tries, car suddenly startet. Service guy checked voltage (Loading 14,3V, switched off 12,3V) and recommended recondition, because bat is sulfated and acid is arranged in layers.
Could I use a Blue smart 12/7 to fix ist? or other proposal?
Can I adjust the recondition voltage to 16V to brake the sulfate?
lead-acidstarter battery
kevgermany avatar image
kevgermany answered ·
It's not clear which charger you have.
If it has a recondition or equalisation setting, you could try that. But you may need to replace the battery, or there may be another fault
elektrowiesel answered ·
I want to buy a Victron, and as I asked, which one will fit best for reconditioning.
According docs I can adjust recondition voltage and procedure?
