cloudberry avatar image
cloudberry asked
Phoenix Multi Compact remote switch
I have an older Phoenix Multi Compact 12/800/35 (18 - no VE.Bus). The DC loads in my system is connected to a BatteryProtect and I also have a BMV-712. I would like to use the remote switch to turn off the inverter if low voltage.
  1. Do anyone know if it is a "pull up" or "pull down" switch?
  2. If it is a pull down switch can I use the Victron Inverting remote on-off cable connected to the DC out of the Battery Protect?
  3. And if it is a pull up switch can I connect directly to the DC out of the BatteryProtect withoyt a relay or do I need a Victron Non inverting remote on-off cable?
  4. Alternatively how can the relay/alarm functionality of the BatteriProtect or the BMV be utilised to achiveve the same?
Battery ProtectRelayinverter current draw
Paul B avatar image
Paul B answered ·
you can reverse the switch operation in the BMV setup
I am pretty sure that that model of phoenix has a low battery cutoff already in the unit so use the ve config to adjust it to suit what you want to do, if not the BMV should work fine across the remote on/off control
Victron BatteryProtect product page
