Fra avatar image
Fra asked
Load control on smartsolar 100/30 and current readings
morning. I went from an Epever tracer 3210AN mppt controller to a smartsolar victron in my solar RV system. Basically to have an all victronenergy system because I already had some victron components. But I was happy with the quality of the Epever controller for the price. Previously I had the whole 12v line of the rv controlled by the LOAD epever tracer output. This allowed me to have many protections integrated in the Epever controller electronics (overdischarge, overload, short circuit etc etc). But above all the reading of the 12v consumption in amperes and amperhours on the Epever controller. This was separate from the Phoenix inverter consumption, which I see on the victron smartshuunt. The smart solar controller does not have all these possibilities because it does not have a real load output with integrated schunt. What do you recommend to return to having electronic protections on the 12v line? Buy a victron smart battery protect that does everything by itself, a victron battery protect controlled by the virtual load, or a solid state relay controlled by the virtual load? How can I also retrieve the consumption reading of the 12v line without buying a second smartshuunt (too expensive at the moment for me)? Thanks
MPPT ControllersRelayinverter current draw
