This problem was mentioned in the past, it was fixed, but now seems to have reappeared: when maximizing an Advanced graph, it minimizes on its own after one to two minutes.
I tested this and it is not doing that for me. I also looked in the change logs what issue are you referring to that was fixed https://www.victronenergy.com/live/vrm_portal:change_log
I see the same behaviour. I tested it with Chrom Version 119.0.6045.106 and Microsoft Edge Browser Version 118.0.2088.76. I also tested the time after which a maximised graph was "normalized" again. And it looked like it happens every time, when new data has to be appended to the graph. So for me it was always at the same time of a minute (I have 1 minute log interval set up), both for Chrome and Edge. So maybe this update of the plotted data resets the maximisation?! Mabe someone of the web team can have a look into that? Thanks a lot!
Sorry to say, but I found, that it seems, the problem still exists. The maximised widgets sometimes stays maximised for two minutes, but in vrm.victronenergy.com and also in beta.vrmvictronenergy.com the maximised windows normalise after 1-2 minutes. I'm using the latest Crome browser for my tests.
42 People are following this question.
