saolor58 avatar image
saolor58 asked
VRM advanced do not shows size of tank and remaining volume
Hi
I have a tank of 40 liters, and with 49% left, the remaining volume must be 20 liters.
See picture below
skærmbillede-2022-05-03-kl-213840.pngVRM shows 0 liters in size and 0 liters in remaining volume. I have rebooted my Cerbo GX. There is running the newest firmware.
At the remote console, I can see both the tank size and the remaining volume.
What can I do to get these values at the advance tab, for tank
Thanks
vrm advanced
4 comments
pwfarnell avatar image pwfarnell commented ·
I have checked mine and they are the same, no volume or remaining fluid. I am sure that these values used to be displayed, perhaps this is a recent bug. @mvader (Victron Energy) .
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ pwfarnell commented ·
thank you both for highlighting, I'll check!
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ mvader (Victron Energy) ♦♦ commented ·
ps, is it ok if we have a look at your system remotely? And what type tank senders/sensors do you have?
pwfarnell avatar image pwfarnell mvader (Victron Energy) ♦♦ commented ·
@mvader (Victron Energy) Yes it is OK, I have GX Tank 140 with fuel, waste and water with voltage senders, one is 0-10V the others are 4.5-7.5V. My Cerbo GX is set up for access, what info do you need to find it and I can supply.
modian avatar image
modian answered ·
the same on my installation and a friend of mine
Firmware release 2.80-9 or 2.85 is no difference.
If you scroll to the Tank summary it will shortly displayed and after a second it disappears
Yes I have just found out that the correct info is displayed for a second or two then overwritten with zeros.
pwfarnell avatar image pwfarnell pwfarnell commented ·
I have just managed to grab a screenshot just as the widget is populated and then one or two seconds later. The screenshots show 2 of the 3 tanks on the GX Tank 140.
@mvader (Victron Energy) this is not the only post reporting this recent bug on VRM with several users seeing the same issue.
screenshot-20220518-222708.pngWidget as it first loads showing correct volumes, other widgets are still loading and are incomplete.
screenshot-20220518-222708.pngWidget after 1 to 2 seconds with 0 values for volumes once all widgets have loaded. Same error on the toilet tank also.
