Since some time widgets in advanced tab are not working correctly. They are blank, can't remove some, can't save created custom. Before all worked correctly.
Since 2-3 days I have the exactly the same problem with the widgets in the VRM advanced tab:
All widgets with charts are blank / data not drawn. Widgets with text are displayed. No remove, change, save possible.
I appreciate any help, cause with this error VRM is nearly unusable. Thanx.
My problem solution:
1) Physical disconnect all device from my Venus.
2) Remove all disconnected devices from Venus configuration.
3) Remove all disconncted devices from VRM.
4) Physical re-connect all devices to Venus.
Within seconds all devices showed up in Venus and VRM. The widget graphs showed up again with drawings and I can delete, add modify all the widgets as normal within VRM.
Maybe this solution is working for others too...
Same here, the Dashboard works but (nearly) none of the Advanced Widget work.
Issue started I think when I started playing with Custom Widgets.
Disconnect devices etc didnt work - still no Data on the Advanced Widgets.
Clearing Caches on Browsers didnt change anything neither.
Any help from Victron on that?
Thanks!
26 People are following this question.
