John Housego avatar image
John Housego asked
Can I use my old split charge relay with my AGM12-100 battery?
I am fitting a Multiplus 500VA and a AGM-12-100 battery to my camper van. In the past I had a standard lead acid service battery. I used a split charge relay with that old installation and I want to know if I can use the same split charge relay to this new system without damaging the AGM? The cabling is already in so it is not easy to change it? Thanks
battery chargingRelay
VictronConnect VE.Bus charging manual
