Hello Victron Community, is there a relay product from victron for disconnecting the SmartSolar MPPT 150/35 from the batteries, while charging with a Centaur Charger?
You could use a Smart Battery Protect is you pay particular attention to the polarity and also the PV should be disconnected first before the battery is disconnected. Choose a suitable generic relay for this purpose.
A more elegant way, if the VE.Direct port is free would be to send a signal to disable the MPPT when you don't want it to charge.
VictronConnect VE.Bus charging manual
32 People are following this question.
