waninae39 avatar image
waninae39 asked
Mutiplus FW update via VRM portal
I have the mutiplus 300 120v model. it accepts the 27 series fw update
im running v4.73
i see that v 5.06 is available
if i update from the VRM portal, will i loose all config data?
, or will it cover the setting after the upgrade?
please advise
MultiPlus Quattro Inverter ChargerVRMvrm firmware update
https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
During the update it downloads the settings and you have to upload them after the update.
There is a step by step video in that manual that shows you the exact procedure -
waninae39 answered ·
can i update the old saved setting from the portal AFTER the update?
or do i have to use the veflash app or some other sw
cheers
Al avatar image
Al answered ·
@waninae39 You can use the VRM > Device List > Remote VEConfigure to download the current settings, and then use VRM > Device List > Firmware update. After the firmware update, upload the VEConfigure file back to your Multi same as downloading it.
