Topper avatar image
Topper asked
PV inverter on L2 with ET112 wrong AC loads value, can an ET340 provide a solution?
I have connected a PV inverter to the L2 with an ET112 and the Victron Multiplus to the L1 of the grid, for this there is an EM24 Ethernet grid meter, see VRM screenshot;
When the PV inverter supplies energy, this is also seen as consumption on L1 for the AC loads.
Within ESS I can only choose that the PV inverter is on the AC1 INPUT, but I would like to be able to indicate that the PV inverter is on L2. Would this be possible if I use an ET340 and connect the PV inverter only to the L2?
Energy Meter3 phaseac
