I have 4 temperature probes, displaying ok in VRM dashboard tab but no graph in VRM advanced tab
Used to work, but today nothing appear
Cerbo 3.10
thank you for your help
Cerbo 3.10
It was reported a few days ago
A work around right now is make a custom graph and the information appears there.
Not the custom date range, the actual custom chart, called a custom widget. If you select the settings button to add a new chart, right down at the bottom of the list is an option for custom widget. My Ruuvi is working in a custom chart.
43 People are following this question.
