flubber avatar image
flubber asked
Status of the battery goes to idle at 15-25 percent [SOLVED]
If I discharge my battery there is still about 15-25 precent left and the battery status goes to idle.
I tried different settings in Venus OS, like BatterieLife On/Off, SOC limit Down/Up but without any success.
Anybody has an idea?
Many thanks in advance.
Best regards
Kai
Multiplus-IIVenus OSSmartShunt
7 comments
What battery? What's the voltage (click on "show details" in the upper left)?
Show us your VE.config settings.
flubber avatar image flubber Matthias Lange - DE ♦ commented ·
Of course.
flubber avatar image flubber commented ·
It is a LiFePo Battery
Inerter tab? ESS assistant settings?
What battery exactly (brand, model)?
It is a (noname?) diy 16x 3,2V LiFePo4 batterie with a JK BMS.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ flubber commented ·
VE.config ESS assistant settings!
Sorry. I hope the summary is enough?
Your highest dynamic cut-off is at 52V and your battery is at 52V so it stops.
I would use the recommended BYD settings for a 16S system:
https://www.victronenergy.com/live/battery_compatibility:byd_b-box
flubber answered ·
@Matthias Lange - DE Thank you for your help. I have changed the dynamic cut-off values and everything works well now.
nickdb avatar image
nickdb answered ·
Your charger settings are very low for a lithium battery. 48V is pretty much flat. Looks like the BMS and chargers aren't configured correctly.
It is in a sustain state so ESS isn't right either.
flubber answered ·
Ok thanks, but apart from that, why is the battery not going below 15-25 precent?
Given that it is in sustain, it would be voltage related. So ESS settings.
Would really need to see a detailed voltage/current VRM chart for the battery.
