ccraven avatar image
ccraven asked
Cerbo gx relays
Hi, does anyone know if it is possible to schedule multiple relay events on the Cerbo gx? I'm aware of the periodic run but this allows only one event. I'd ideally like to schedule a relay event to occur in the morning then again in the evening. Is this possible?
Many thanks
cerbo gxRelay
derrick thomas avatar image
derrick thomas answered ·
The possibilities are almost endless with node red
ccraven avatar image ccraven commented ·
Thanks for the info. I've enabled the large image type but am not able to access Venus.local:1881 nor does it work using the ip address. Any ideas why this may be?
By the way, although I see that large image type is selected, I don't see where to enable node-red. This option appears not to be there.
matt1309 avatar image matt1309 ccraven commented ·
Hi @ccraven
To enable node red via GX device:
Go to gx device via ip or venus.local
settings -> Venus os large features (at bottom of the settings page) -> enabled node-red.
One thing to note is it uses ssl. so you'll need https://venus.local:1881 or your gx device ip in place of venus.local but you need the s in https.
PS. I have similar setup however i use shelly smart switches instead of gx relay as i find them more flexible.
ccraven avatar image ccraven matt1309 commented ·
Thanks, I see large image type is selected but at the bottom of the settings page there is no Venus os large features. I only see I/O options at the bottom of the settings page.
My firmware is version 3.10.
