teejmiller avatar image
teejmiller asked
Installing kplex on Venus
Hello, I am looking for assistance on figuring out a way to install or compile kplex on my Venus Pi currently running 2.32. With kplex I will be able to use GPS data on the Venus system in a way that is not currently possible with the stock software (via TCP).
I've tried to download the .deb and use opkg to install with the following error:
root@raspberrypi2:/kplex# opkg install kplex_1.4-1_armhf.deb
Collected errors:
 * Solver encountered 1 problem(s):
 * Problem 1/1:
 *   - package kplex-1.4-1.armhf does not have a compatible architecture
 * Solution 1:
 *   - do not ask to install kplex-1.4-1.armhf
I have also tried to compile kplex from tar source, but make and cc are not present in VenusOS.
Has anyone successfully installed kplex? If so, please share. Thanks!
Venus OSCCGX Color ControlVenus GX - VGX
