gberg avatar image
gberg asked
Smart Battery Protect - Remote Switch and VictroncConnect app
I'm wondering is if you can use a remote switch connected to the remote connector and bluetooth switching together.
For instance if the load is turned off by the remote switch, can you then turn on the load using VictronConnect app?
VictronConnectBattery Protect
Justin Cook avatar image
Justin Cook answered ·
The switch -being physical- will override the app if the switch is OFF.
If the switch is ON, you can use the app to turn it OFF or back ON, but if the switch is OFF you cannot use the app to turn it ON.
