Beau Sandford avatar image
Stopping generator after fault
Hey,
Got a setup with a CCGX and Multiplus 5000/70/48 on a 7KVA diesel generator. I've been having some issues with the RCD in the generator tripping when the Multiplus goes to put a load on it after an autostart. I assume this was to do with the ground relay which I've now disabled, however with this I noticed an odd problem... The CCGX, will realise the generator hasn't started providing power and provides the subsequent alarm, however continues to call for the generator. In my case this meant the generator ran for an hour before I noticed it was running without load.
Are there any settings that may turn off the generator after the CCGX alarms from the generator not being present? I haven't seen anything so far.
Cheers,
Beau.
MultiPlus Quattro Inverter ChargerCCGX Color ControlGenerator
Hi @Beau Sandford, no there is no such setting.
I’ll keep it in mind for future developments though. Good weekend, Matthijs
