Hi since a few days I get randomly 10 second Error Code #66
I have not changed anything on my system and I never had a problem in two years.
Any idea why this just pops up for 10s?
Check the wiring. Everything up-to-date?
What versions are the chargers on? Have you updated the GX recently, or does it auto update?
If you are behind, I would suggest you update the MPPTs.
Howdy, got same error.
Any ideas? Thanks!
I just called tech support, and it may be a VE Bus Smart Network setting that needs to be turned off as it is its own system. Will try...
How to change the Owner of a VRM installation
60 People are following this question.
