Do you have to run the ground wire from the DC to DC charger (12-12 30) to the negative of the battery or can I just land it to chassis ground in the back of the van and just run the positive wire to the battery with a fuse?
Chassis ground is perfect.
I do the same in my Sprinter and Berlingo.
The chassis is the best MINUS conductor yoz can get in a vehicle.
However, it us subject to corrosion if you remove the paint, hence before you screw on your MINUS wire use enough Contact Greese (e.G. ENSTO) to seal the whole hole and area.
Victron DC to DC Converters Product Range
__________
38 People are following this question.
