Fiberglass hull. 24 volt house bank (lithium), 24 volt Thruster bank (AGM). Approximately 40' from house bank to thruster bank location.
Provided both battery banks share the same ground/minus, the non isolated version is good enough. When in doubt, use the isolated version - even if later turns out that both have the same ground.
Victron DC to DC Converters Product Range
__________
27 People are following this question.
