engmarc avatar image
engmarc asked
Quattro 5000 24v connection to Argofet 200-3
I'm designing a 24v system with three separate and different Li battery banks (800ah, 800ah, 400ah) which will be connected to an Argofet 200-3.
The question I have is can I cannect my Quattro 5000 24v to this Argofet and will the Quattro charge the three banks and then when needed use these three banks as a load? I suspect the Argofet will not allow a load draw from it but not sure how to get both charge and load via the same connection to the Quattro?
I'm familiar with the Argofet Battery Combiners for loads but again how to use these with the Quattro?
If the Quattro has a separate charge and load input that will solve the problem?
MultiPlus Quattro Inverter Chargerbattery chargingLithium BatteryArgo FET Diode
