I am looking for a Compatable wifi module for the CCGX Victron colour controller or how to configure eg, TPlink usb wifi module to be recognised by the CCGX.
email: ebrahim@brighthousesolar.co.za Country: South Africa
I bought this and it works fantastic!
CCGX Long Range WiFi Module (ASUS USB-N14)
I ordered this unit and got the one below....Newer version?
Great price!
I have tested this WiFi to LAN bridge on a CCGX and it does a good job.
+) stable WiFi connection
+) good WiFi reception
+) no driver or configuration needed on the CCGX
+) CCGX USB port can be used to supply power to the bridge
+) inexpensive
-) production quality (cheap appearing)
-) computer is needed to preconfigure the bridge
-) Not 5Ghz capable (there are 5Ghz capable bridges available)
This is a good alternative, to the WiFi USB adapters. Maybe useful for someone searching for a low-priced and good working CCGX WiFi solution.
BR
Compatible wifi adapters are listed here in the CCGX manual:
https://www.victronenergy.com/live/ccgx:start#internet_connectivity
Hi Guy. I have bought the Asus model. It comes with a CD. Obviously I can't use that on the color controller. Can I just plug the aerial into the USB port?
Hi @MMesserli, welcome to the Community!
That is not possible, sorry.
That being said, it is certainly possible that other wifi devices will work with the CCGX - it is just that they have not been Victron-tested and certified to work.
16 People are following this question.
