Philmoon69 avatar image
Can I synchronise charge state between BlueSolar, BMV, easy solar, smart solar and raspberry Pi?
Hi guys and ladies
We have the following hooked up to a raspberry pi ( our sweet sanctuary on vrm )
x2 blue solar regulator 100/50 hooked straight in via usb
1x smart solar regulator 100/50 hooked straight in via usb
1x 712 bmv again hooked up via usb
1x multi plus 3000 VA via mk3 usb
They work perfectly in regards to online and communication (which was supprisingly simple to do).
But we have noticed the smart solar is always on absorption (for about an hour ) when the other two are on float.... the only difference I can see is that the bmv and smart are commincating via bluetooh (which I can not do with the other two as they cannot have Bluetooth leads in as well as the cables to the raspberry pi)
Is there some way to network these devices using the pi (vensux gx )
any help would be much appreciated
MPPT - Solar Charge ControllerBMV Battery MonitorVenus GX - VGXBluetooth
Philmoon69 answered ·
ok not really what I was expecting as an answer for such high end gear but I suppose its an answer. thank you for your response
This is normal and expected behaviour. The units are acting independently at the moment, and each will have different startup voltages and tail currents that decide their state.
It is planned to allow SmartSolar charge controllers to synchronise charge states.
However this feature is not planned for BlueSolar charge controllers at this stage.
In my experience the difference in total Ah delivered is not significant, as this occurs at the end of the charge cycle when the batteries are the limiting factor in what can be absorbed, not the solar production or the MPPT current limits.
