petajoule avatar image
petajoule asked
Can I use a GX device as Proxy for MPPTs?
I hope I can explain what I am trying to achieve.
Right now, I am always connecting from VictronConnect to the MPPTs via BT dongle, looking up MPPTstats, history, fw updates etc. all working fine.
However, there is an installation I would like to consolidate by ditching BT dongles and connecting two MPPTs vie VE.Direct cables to a Venus GX.
Now my question is if I will see the same information via the Venus GX like I do when "talking" directly to the Bluetooth of the MPPTs?
In short: Will Venus GX serve as a proxy for these devices and if not: why not? ;-)
MPPT ControllersVenus GX - VGXBluetoothVE.Direct
klim8skeptic avatar image
klim8skeptic answered ยท
Hi PJ.
You can view pretty much the same info. But you cant update or change settings, so don't lose your dongles.
petajoule avatar image petajoule commented ยท
Okay! Looks good. So if I understand things correctly, for the bigger SmartSolar MPPTs with builtin Bluetooth you get best of both worlds by connecting them via VE.Direct cable to a GX.
And for the smaller ones with Dongle via VE.Direct it's an either-or.
0 Likes 0 ยท
klim8skeptic avatar image klim8skeptic โ™ฆ petajoule commented ยท
Hi PJ,
"And for the smaller ones with Dongle via VE.Direct it's an either-or."
That's right. My small array is a bluesolar, and I have left the disconnected dongle screwed to the wall for future firmware updates. The bvm is on a usb>ve direct cable, and can be updated via that.
0 Likes 0 ยท
