noel1968 avatar image
noel1968 asked
Battery settings
I need advise on what battery setting to be do be done in VE Configure. I have an Easy solar 3000/48 with ESS enabled. I have 4 x 12v/200 AH flooded tubular batteries (Exide Indian brand) which are not listed.
What option needs to be checked in this list... Flooded tubular plate or No corresponding defaults
batterybattery system voltage
ejrossouw avatar image
ejrossouw answered ·
I'm not an expert, but for me if it is not AGM or gel, the choice is obvious, flooded tubular plate. I'd strongly recommend to check the manufacturer recommendation for float, bulk, absorb and bulk settings as this is much what is behind these profiles. You can even configure your own profile based on it to 100% sure.
