shop6 avatar image
shop6 asked
Why isn't the energy meter EM540 displayed under Energy Meters in the CerboGX?
The EM540 is not shown in the Cerbo console
CerboGX v2.75, no ESS, used in pv island
EM540DINAV23XS1X, configured as 3Pn, L1: MPII-AC-OUT1 to Load, L2: Grid to MPII-AC-IN
Cable Victron "USB-RS485-WE"
The counter works.
The cable is OK and properly connected because it works with the USC program.
The cable is also recognized by the Cerbo as:
usb-FTDI_FT232R_USB_UART_A10N4HQX-if00-port0 -> ../../ttyUSB0
Changes to the product ID in the cable with ft_prog are visible in Cerbo
usb-FTDI_USB-RS485_Cable_A10N4HQX-if00-port0 -> ../../ttyUSB0
Changes in Cerbo in ../../etc/udev/rules.d/serial-starter.rules did not work
Modification of ../../etc/udev/rules.d/serial-starter.rules had no effect.
cerbo gxEnergy Meterrs485
You need to update the Cerbo to version 3.00.
shop6 avatar image
shop6 answered ·
Thats it! Thank you so much.
Btw: it works with original serial-starter.rules.
Not sure, if the cable has the original product discription, because I have changed it a lot.
Now the cable has the description FT232R_USB_UART, not USB-RS485_Cable and not USB-RS485-WE (as shown at the device)
shop6 avatar image
shop6 answered ·
Ich sehe gerade, dass Matthias Lange für das Service Team Döbeln arbeitet.
Eine von nur(!) zwei Victron-Partnern zwischen Rügen und Erzgebirge...
stefanj avatar image
stefanj answered ·
Hi, I've the same Problem but with CerboGX running firmware version v3.10 and original Victron USB Interface Cable (ASS030572050 RS485 to USB Interface 5m) recognized as:
Bus 003 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
in the CerboGX. It's working well with USC7 so the wiring with the EM540 is ok.
EM540 is connected and showing up under Settings -> Energy Meters -> BX01200340011 but not in dbus-spy or with any grid measurement data.
Any Advice?
