cbscpe avatar image
cbscpe asked
Can I use the RS485 of the Waveshare CAN/RS485 HAT to connect to the energy meter ET112?
I have installed Venus OS 2.92 on a Raspberry Pi 3B+ and use the combined Single CAN Bus and RS485 Hat from Waveshare. I have successfully connected the Pylontech Battery via the CAN Bus and now I need to connect the ET112 Energy Meter to the Venus OS and I was asking myself if I can use the RS485 that comes with the Waveshare hat or if I need to use an USB->RS485 Adapter.
Venus OSEnergy Meter
awalkerinuk avatar image
awalkerinuk answered ·
I reckon you can, I would give it a try.
There might be an issue with drivers depending how the Venus OS software deals with the RS485 being on the waveshare shield and not on a USB > RS485.
But I would not have thought you cant do any damage by try it. Worst case it just will not show up!
cbscpe avatar image
cbscpe answered ·
It just does not show up. However, as the RS485 on the Hat ist just using the UART on Pin 8 and 10 of the Expansion Port it definitively has a device name in Linux and by modifying the serial-starter.rules in /etc/udev/rules.d it should be possible to trigger the RS-485 task for it. I did not try it, because I found a USB to RS-485 Adapter in my toolbox with the required FT232R chip and that did work out of the box, however I will give it a try with the RS485 on the Hat has this would be very convenient and save one of the spare USB ports.
cbscpe avatar image
cbscpe answered ·
Just found out, you probably cannot, the serial interface on the GPIO has been reused for the bluetooth since Rapsberry PI 3 and the serial interface on the GPIO is no longer a hardware UART. So it is not worth to try it as most likely Venus OS does not provide this driver. In any case, I have a working setup and most likely will have to use a USB-Hub with enough ports.
bindpe avatar image
bindpe answered ·
Hi
can you tell me which USB to RS-485 do you use to operate "out of box"
I want to read out my smart meter via HAGER EHZ001K to the Venus OS, to build up an ESS
is this possible`?
thank you
