bonzabuy avatar image
bonzabuy asked
VictronConnect fails to copy all settings to 2 x Quattro 2's (parallel)?
Anyone else having issues copying settings via VictronConnect?
The option to 'copy all settings' is there, but when pressed, no confirmation etc.
The slave unit flashes 'mains on' once and then flashes 'inverter on' once in continual succession. I am wondering if this unit has an issue as it has behaved differently from the start.
Firmware on both units up to date. I can manually change settings on each. Trying to copy settings from either will not work. Have restarted the app (MacOS) and it has crashed at least once).
Is VC a fail? Should I go back to VEConfigure?
VictronConnectgrid parallel
Alexandra avatar image
Alexandra answered ·
@bonzabuy
Use VE config.
There are still some kinks in VC for the more complex systems.
bonzabuy avatar image bonzabuy commented ·
That's a shame - using MacOS to configure is one of the reasons we are trialling Victron. Reliability is key, but the era of forcing Windows only has passed.
Victrons training shows 3 phase setup via VC so I really thought the kinks like this would be ironed out...
VictronConnect Manual
Download for iOS / Android / Mac / Windows
