tougma avatar image
tougma asked
Time in bulk greater than 1440 minutes (24 heures) a day
In recent days, I frequently have the "Time in bulk" that abnormally exceeds 1440 minutes (24 hours) in a single day. Usually I record between 12 and 13 hours of bulk duration.
What could be the reason and how to fix it?
PS: I am in west Africa, I use a Multi RS Solar 48/6000/100 with the last update and I read the data by Bluetooth on my phone
battery chargingsmart solar charging behaviour
tougma avatar image tougma commented ·
I can understand that it could be exactly or less than 1440 minutes, equivalent to 24h00mn, only if the charge continues all the day.
But in my case, I read during nights 0 watt in solar panels power (0A and no more than 10V). In addition, I recorded three times 1443, 1444 and 1446 minutes of bulk duration a day.
Michelle Konzack avatar image
Michelle Konzack answered ·
Can it be, that the night is so bright, that the SolarCharger does not go into sleep?
Thank you for the answer. I can understand that it could be exactly or less than 1440 minutes, equivalent to 24h00mn, if the charge continues all the day.
But in my case, I read during nights 0 watt in solar panels (0A and no more than 10V). In addition, I recorded three times 1443, 1444 and 1446 minutes of bulk duration a day.
mvas avatar image
mvas answered ·
Does the charge controller actually display "BULK" mode after sunset? Is the battery pack ever getting fully recharged?
On the charger screen (Multi RS Solar 48/6000/100), it displays no panel power after sunset. But, when I connect by bluetooth with it, it still continue all the day to be in bulk mode in historic data.
VictronConnect VE.Bus charging manual
