returnofthemac avatar image
returnofthemac asked
Many Victron units but which Temperature input should I use
Hi, I have a Lynx Distribution system with Lynx Shunt that has a Battery temp sensor input a MP-II also with a Battery Temp Sensor input, Smart Solar MPPT and a Cerbo GX. I am connecting the Lynx, Smart Solar and GX together with VE Can and the MultiPlus to the Cerbo GX with VE Bus, The Cerbo obviously has its 4 temp inputs.
So the question is do I have to connect up multiple Battery Temp sensors as I have 3 sent with the differing devices or can I just connect one? And if so which one do I connect up?
Multiplus-IIcerbo gxbatteryTemperature Sensor
JohnC avatar image
JohnC answered ·
Hi @Returnofthemac
You only need one, but see the DVCC section of the Cerbo manual for how to share it with the other devices that may need it. They're not necessarily all the same, so ensure you use the right one for the device it's connected to.
I chose the Multiplus one, close to the batteries usually..
seb71 avatar image
seb71 answered ·
In my system, for battery temperature I am using the temperature sensor connected to the SmartShunt.
In addition, I connected the temperature sensor which came with MultiPlus II to Cerbo GX to monitor room temperature.
