chezz2305 avatar image
chezz2305 asked
Dyness Battery losing track of SOC over time
We have a Dyness battery that has been installed for a few months now. We have noticed that over time it will lose track of what the actual SOC% of the battery is. It will only realise it is too low once the voltage drops below the BMS safety minimum and then shuts down completely until power restores from gird to start the battery up.
Is this a problem with the firmware version or something else?
Lithium BatteryBMSbattery
Mike Dorsett avatar image
Mike Dorsett answered ·
there could be an efficiency setting in the BMS firmware that needs tweaking. However, SOC is an integrated value (computed over time) NOT measured, so should not be used for protection or gen start functions. These should always be based on battery cell voltages. Normally, the SOC is reset at either Low or High cell voltage, sometimes there is a convergence algorithm that steers the SOC to what it should be for the current cell voltage - with allowance for charge / discharge condition and age of cells.
If you don't get to the reset condition then without the complex convergence algorithm, the SOC will drift away from the "correct" value.
Best to look at how your gen start is configures, and switch this to a voltage measurement.
chezz2305 answered ·
As the communication is setup between the battery and Inverter the SOC is automatically used as this is how they were designed to be used as this can adequately control the battery according to the manufacturers desired parameters. Using voltage to control a Lithium battery that has communication is just not a solution. If this is the solution then the battery is not functioning as it is meant to as all the other Lithium batteries with comms I have seen do not have any such problems.
Is there a way I can tweak the efficiency settings to make this battery behave as it was meant to?
eric-tarkleson avatar image
eric-tarkleson answered ·
Since the Dyness battery communicates its own SOC to the victron gx device this is really a Dyness support issue. However I see this often with other battery manufacturers as well. We make sure to use the cell or battery overall voltage to determine when the battery is empty or full, not the SOC communicated via the BMS. (Just like Chezzz said).
Have you tried letting the battery sit at 100% for an extended period of time? When we see this behavior usually its because the battery is becoming imbalanced. If the battery is fully balanced the SOC algorithm should revert to 100% and be accurate for awhile.
anthony avatar image
anthony answered ·
I am experiencing the same issue with a single Dyness BX51100 connected to a MPII, a Cerbo and an MPPT 150/60. The battery SOC is dropping with zero load (MPII off) and the charge controller is not charging the battery as it thinks the voltage set point has been reached due to the bms signal..
However I have another Dyness system working normally.
I haven't fully got to the bottom of it yet.
I would be interested to know more about the specific model of battery and the other components in your system? Anthony
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
Battery Compatibility
