I have not been able to access the VRM for the past 4 days. If I go to the boat all is good. here is the error message. Installation too busy realtime data link disabled
Have you tried a reboot of the GX? You may need to do it on your next visit, and you can also set it up to reboot after a set time when comms are lost.
yes I did a number of times since last visit to the boat I installed 2 bluetooth gas tank sensor and added GPS antenna to victron gsm/lte module and removed a usb gps i had before. and yes I did set up reboot on no comm but seem not to work. any other help?
Ok. This 'too busy' thing might happen more frequently with one of the less powerful GXs, like a CCGX. It may be struggling because you have a lot of kit connected, or there's one particular device that's causing it issues. Could even be something simple like a dicky cable.
Maybe try the elimination process to try to find an offending device. Even reboot each time you remove one. So, patience and perseverance. I wish I could give you something more clear-cut to run with, sorry..
All the devices that are attached are needed for my configuration. Shall i turn off internal Bluetooth since i have a USB bkietooth. I also turned off the wifi hotspot. Shall i chance the USB dongle? Maybe one you suffer and i change of? Or can it be since i have census large and activated signal k? Even though i did this 3 months ago
So it seems you have her well loaded up. And of course you need it all! :)
This is your issue. Victron keep developing features too, and sometimes warn that their use will add to cpu load. It still may be some particular device/feature that's the main cause, and perhaps even the frequency at which something is set to operate.
Maybe someone else has clues as to where the bad offenders dwell?
I went to boat today. I realized issue with internet so i separated the boat internet from the victron internet. I use the 4g victron dongle dongle. I removed the wifi network from cerbo. All works and i checked the system is online and connected including vrm yet it still says in the apps that is not connected. Maybe refresh on the server side on your side?
Can you please check into this may e an issue on the server side or authentication? The cerbo is sending data i have signal k sending data to sailogger no problem.
How to change the Owner of a VRM installation
51 People are following this question.
