tom-brzeski avatar image
tom-brzeski asked
Victron Multiplus II 3000/48V enable L2 when inverting
Is there possibility to enable L2 while inverting? I've read documentation and it states that L2 line is only enabled when onshore power is present.
I apologize, I am newbie. I have large bank and I want utilize both L1 and L2.
I assume there must be a configuration setting in VEConfig app.
Thanks
Multiplus-IIVEConfigure 348v battery
Mike Dorsett avatar image
Mike Dorsett answered ·
No this does not happen. Why would you want this output on? It has been designed to only power up when the external AC input is present, to reduce loading on batteries from water heaters, AC units etc. If you have loads like this you want to drive from battery, and the bank is large enough, they can be connected to the L1 output.
