josligitanu avatar image
josligitanu asked
Multiplus inverter switched off after 10 minutes, yellow lights blinking
Hello, after two weeks off i turned on the inverter Multiplus 3000 to find no power after 10 minutes. The flow and bulk yellow lights were flashing. I reseted the pylontech battery and the inverter but it kept on happening. I checked the error codes of the manual but none really define the problem. The battery shows its full but the inverter switch out after 10 minutes everytime and the yellow lights on the charger side of the inverter come back blinking. I need help to understand if the problem comes from the battery or the inverter. thank you
MultiPlus Quattro Inverter ChargerLithium BatteryPylontech
derrick thomas avatar image
derrick thomas answered ·
Download victron tools app on your phone or mobile device to decipher what the LEDs are telling you.
josligitanu answered ·
ok, i will try that. Thank you
After research Victron tools app shows that the 3 yellows lights on the inverter mean " hardware or EEPROM ERROR " Do someone knows what it means and how to fix it ? Thank you
That is an internal error. I would try updating to the latest firmware if it isn't current. If that doesn't fix it you might have to get in touch with your installer for a return to repair.
