kadenatcr avatar image
kadenatcr asked
Multiplus-II AC Input and low battery voltage disconnect
If the battery banks voltage drops below the low voltage disconnect setting on the Multiplus, the Multiplus will discontinue operation and not allow any incoming AC current to charge the batteries to bring the battery bank up to a sufficient voltage.
My question is this: in the Multiplus-II, can shore power charge your battery bank even if the battery bank voltage drops below the low voltage disconnect, rendering the inverter/charger inoperable?
Multiplus-IIbattery charginglow battery warningshorepower
looknow12 avatar image
looknow12 answered ·
Following
