tobyfw avatar image
tobyfw asked
Data logging in VenusOS: SmartMPPT Limits and Fronius MPPT2
Dear community,
1. how can I (preferably, automatically) check whether a SmartSolar MPPT is currently limited (due to no-feed in and full battery)? (from VRM, Venus, Node-RED, Bluetooth...) - I can see this data in VenusOS for my AC-coupled Fronius Primo, under "Zero feed-in power limit", but not for the Victron MPPTs (if this value is below the maximum inverter power, this means there is active limiting)
2. My AC-coupled Fronius Primo is working fine, and set up in Venus according to the Victron documentation. However, it does not seem to send information on the currently generated power per string. However, it would be good to have this data in Venus for optimal analysis. Any suggestions? The value does not seem to be on MQTT Broker or DBus, but maybe I am mistaken. There seem to be some very old python scripts doing that, but maybe there is an option with better integration in Venus.
Thank you!
MPPT ControllersAC PV CouplingFroniusfeed-in limit
