koenbro avatar image
koenbro asked
OrionTR and SmartShunt parameters for a Renogy Deep Cycle AGM Battery 12 Volt 100Ah
Variations of this question popped up before on this forum, but here I go with my specific need. I need the config settings for an Orion TR (non-isolated, if that makes any difference) charger for a Renogy Deep Cycle 12V 100Ah AGM battery (they call it a "valve regulated sealed lead acid battery").
The Renogy website has an FAQ which only mentions the following:
"7. When using a charge controller, which battery type should I set? You should choose the SLD battery settings."
What does SLD stand for and how to apply this to set up the Orion charger?
Also I am monitoring this battery with a Victron Smart Shunt 500. Any special config for that ?
Thank you all.
SmartShuntorion-tr smartAGM Batterylead-acid
kevgermany avatar image
kevgermany answered ·
There's a good data sheet her, I think it's the right one: https://www.renogy.com/content/RNG-BATT-AGM12-100/AGM100-Datasheet.pdf
Says absorption (cycle use) 14.4-14.8V, float 13.5-13.8V
Most of us would use lower settings of the ranges given.
Most of the shunt settings can be left at default for now, but do set the battery capacity.
koenbro answered ·
I contacted Renogy and the support tech pointed to the same sheet (I had not seen it before); she did not have any more info. Thank you for your response.
