campervan avatar image
campervan asked
AGM with Orion Smart TR 12/12 18 charge current and temp compensation
According to the datasheet of the AGM batteries the charging current without temperature compensation must be limited to 0.2C. When charging a 60Ah AGM with the smallest Orion Smart Tr 12/12-18 the chare current will be 18A or even higher at normal temperature. This corresponds with at least 0.3C. The system will be put in a relative small compartment so I expect that during charging the temperature will rise to 30-40 degrees. Because the Orion Smart does not support temperature compensation and adjustable charge current this seems a less optimal combination. Is there a better solution?
My current thougts are to use a MPPT charger and connect a 12-24V DC/DC converter to the PV input. The Smart MPPT has options for temperature compensation with an external sensor and adjustable charge current setting.
MPPT SmartSolarorion-tr smartAGM Battery
5 comments
You expect your battery temp to rise by 30-40 degrees? (Celsius?)
campervan avatar image campervan klim8skeptic ♦ commented ·
Based on some simple thermal calculations my estimation is that the ambient temperature of the cabinet can be between 30 and 40 degrees Celsius. The battery might become warmer due to internal heat development.
klim8skeptic avatar image klim8skeptic ♦ campervan commented ·
Ouch. What would the expected ambient temp be?
Sorry, my answer was not 100% accurate.
Ambient outside the cabinet: 25-30 degrees maximum (only during warm weather).
Inside temperature of the cabinet: 10 degrees higher (35-40 degrees during warm weather) due to dissipation in the DC/DC converter and battery. Dissipation of the Orion is approximately 30W when charging at full current and that's a lot in a small cabinet.
yann-berry avatar image yann-berry commented ·
What did you decide to do in the end ? Did you connect the Orion output to the MPPT input ? That seems odd but I'm curious about that.
