buryck avatar image
buryck asked
12v AGM leisure battery charging from van alternator
Hello, i have a Ford Tansit van converted into a camper and i would like to charge my leisure battery from the alternator. I was thinking of using the Orion-Tr dc to dc charger. Would this be enough, or is this even a good ideea? Or is there another way of doing it.
Thanks alot :)
battery chargingorion-tr smartAGM Batteryalternator
tozz avatar image
tozz answered ·
The Orion-Tr DC-DC charger is specially designed to charge a leisure battery and separating it from your starter battery. And yes, only a Orion-Tr would be sufficient.
There are other solutions, such as diodes or simple relays that switch on at 14V, but those are not necessarily cheaper. I'd prefer the Orion over a diode or relay.
buryck avatar image buryck commented ·
Thank you very much
Which version should i get, the isolated or non-isolated version? I don't know the difference betwen them is.
tozz avatar image
tozz answered ·
The isolated versions have their own negative circuit for both batteries, while the non-isolated version share the neutral.
You have a car/van/camper, where the chassis is usually used as ground/neutral/negative. You can go for the non-isolated version.
Thank's alot.
southsideph avatar image
southsideph answered ·
I Use the Orion 12/12 30 Isolated in my camper conversion without any issues. I use it in isolated mode which the camper electrics are completely separate from the van electrics.
