ronbeton avatar image
ronbeton asked
P1 to RS485 converter instead of ET340
I have a smart grid meter with DSMR v5 so it transmit a p1 telegram every second. I'd like to use this data as grid meter in ESS. In my understanding this is even more accurate then an ET340 which has a refresh rate of 2 seconds.
I'm thinking of the following solution:
  • I found a p1 to RS485 converter P1MB - P1 to Modbus converter | Xemex
  • After converting I could use the Victron Zigbee <-> RS485 bridge to transmit over the air
  • Connect the other end of the Zigbee bridge to my Cerbo.
What do you guys think? Is this feasible?
Energy Meterrs485
rns avatar image rns commented ·
I'm looking for a similar solution. (see my question : https://community.victronenergy.com/questions/203592/p1-port-as-energy-meter-for-multiplus.html)
Did you make progress in this ?
pyrorider avatar image
pyrorider answered ·
I guess you need to use VenusOS on a PI and configure the drivers for your meter as the mapping of the rs485 registers probably is not similar to the one of the ET340 or the ABB B23
can you help me to finde the drivers. My digital energy meter is installed a few days ago.
I can read al the values with an esp8266 so the P1 port is active. Would be nice to feed this info directly to the victron multiplus II
Now i stear the multiplus via home assistant to compensate on fase1 for fase2 or 3 but the multiplus could do that on his own if he could get the data.
matt1309 avatar image matt1309 rns commented ·
This might be a start if you know python.
dbus-shelly-3em-smartmeter/dbus-shelly-3em-smartmeter.py at main · fabian-lauer/dbus-shelly-3em-smartmeter · GitHub
Can tweak this driver to receive the data from your meter rather than from shelly energy meter. Essentially change the function getShellyData to a function that'll receive data from your meter. And then tidy up/remove other shelly specific functions but this would be a good guide if a driver for your specific meter doesnt exist.
Energy Meter Selection Guide
