Hello, What is the final solution for error # 17?
Hi @Antonio
Have you read this?:
https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes#error_17_-_original_master_missing
So: first check wiring, temporarily use new VE.bus UTP cables to see if problem persists.
If still having problems, contact support (your installer, distributor)
https://www.victronenergy.com/support
Hi Boekel,
I have not had any problems in any of my facilities. This error is new to me, but I am told that when a specific equipment is used, it could be said that this equipment emits some interference that causes error 17? It is previously connected to a skylla ip44.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
10 People are following this question.
