The 1-1 rule a maximum as i understand it. So there should be no problem having 3 x 5KVA MP2 in 3 phase config with 10.3 fronius Symo as the AC PV.
The 1 to 1 rule applies per phase. The Fronius 10.3 is effectively a 3 x 3.4 KVA inverter from the point of view of your multis.
So everything is shiny with your configuration
79 People are following this question.
Placing 3 phase loads between ET340 Meter and 3 Multiplus II
Multiplus II 48/3000 + Fronius 3000 on AC-Out (Essentials) - Max power to Non-Essential?
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
Fronius Primo 5 & Multiplus - Diagram
Unbalanced load in a 2x Multiplus II 3000/48 system (Germany)
