Hi my DC system is not showing up in the VRM Dashboard.
Under Advanced view, I can see the DC load?
Have you set the "has DC system" to on or enabled on your Venus system under the system setup. See https://www.victronenergy.com/media/pg/Cerbo_GX/en/configuration.html
Yes its on.
I also tried to re-enable it.
May not be the same issue, but right now VRM dashboard doesn't show my (VE) PV Charger, even though it's showing in the VRM device list, and shows on the Touch70. Also, VRM is hanging up each time I attempt to connect for firmware update check and/or config updates.
How to change the Admin of a VRM installation
50 People are following this question.
